Cisco Prime upgrade 1.3.x to 3.1
compnet.mtc
Hi Guys,
I am about to upgrade cisco prime from 1.3.0.2 to 3.1. I have limited knowledge on prime.
And i about to use Inline Upgrade procedure.
After searching the path, i got is like below :
- Patch to PI_1_3_0_20-Update.4-16.tar.gz
- Upgrade to 2.1.0.0.87
- Upgrade to 2.2
- Upgrade to 3.0
- Upgrade to 3.1
And that i know i need to concern about the VM Resource to meet the requirement.
Beside of that, how about the license?
Should i need to worry about it?
Waiting forward for the suggestion.
Leo Laohoo
It is easier and faster to just export your data and then import them to a newly installed PI 3.4.
