hi
i try to upgrade cisco prime from 3.10.0.0 to 3.10.2 but failed two times now in patch install task 4:
Deleted all backup files in defaultRepo
rit02-1pa-cis00/admin# dir disk:/defaultRepo
Directory of disk:/defaultRepo
2399667100 Mar 07 2024 12:39:07 PI-Upgrade-3.10.x_to_3.10.2-0.0.90.tar.gz
Checking disk space:
Directory of disk:/
20 Dec 20 2023 14:48:06 crash
4096 Mar 07 2024 12:38:16 defaultRepo/
4096 Mar 01 2024 14:11:07 ftp/
16384 Oct 07 2021 06:28:26 lost+found/
4096 Dec 20 2023 23:58:48 sftp/
4096 Dec 20 2023 14:46:56 ssh/
4096 Dec 20 2023 14:46:56 telnet/
4096 Mar 01 2024 14:17:09 tftp/
Usage for disk: filesystem
2464727040 bytes total used
132745900032 bytes free
141430923264 bytes available
rit02-1pa-cis00/admin# show disks
temp. space 1% used (3728 of 1983056)
disk: 2% used (2406960 of 138116136)
Internal filesystems:
all internal filesystems have sufficient free space
NCS Stop
Compliance engine stopped
Completed shutdown of all services
Ceck NCS Status
rit02-1pa-cis00/admin# ncs status
Health Monitor is stopped.
Database server is stopped
FTP Service is Stopped
TFTP Service is Stopped
Matlab Server is Stopped
Matlab Server Instance 1 is Stopped
Matlab Server Instance 2 is Stopped
NMS Server is stopped.
WSA Service is stopped..
SAM Daemon is stopped.
DA Daemon is stopped.
Compliance engine is not running
Starting the upgrade:
rit02-1pa-cis00/admin# application upgrade PI-Upgrade-3.10.x_to_3.10.2-0.0.90.tar.gz defaultRepo
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Please ensure you have a backup of the system before proceeding.
Proceed with the application upgrade ? (yes/no) [yes] ? yes
DO NOT press ^C while the upgrade is in progress
Aborting upgrade with a ^C may leave the system in a unrecoverable state
Initiating Application Upgrade...
Stage 1 of 7: Transferring file ...
-- complete.
Stage 2 of 7: Unpacking file ...
-- complete.
*** System will reboot after a successful installation of this package ***
After reboot, please login again into the server to check status
Stage 3 of 7: Executing pre-install ...
-- complete.
Stage 4 of 7: Upgrading binaries ...
% Application install/upgrade failed with system removing the corrupted install
Check NCS Status:
sh: /opt/CSCOlumos/bin/wcsadmin.sh: No such file or directory
sh: /opt/CSCOlumos/bin/CliAuditLogging.sh: No such file or directory
ERROR : Audit logging script CliAuditLogging.sh not available.
Try NCS Start:
rit02-1pa-cis00/admin# ncs start
temp. space 1% used (3524 of 1983056)
any idea whats going wrong?
tia tom
