I have a Cisco Prime LMS 4.1 in soft appliance, all process are running in normal state and suddenly
UPMDbMonitor and UPMProcess are in a Administrator has shut down this server state. Why is this happen?
I start again these two processes and stay in normal state, but some time later they come down (Administrator has shut down this server)
The best you can hope for is that the database transaction log has become corrupt. To check this, shutdown dmgtd, then look at NMSROOT\databases\upm. If you see a upm.log in there, delete it (del /f/q upm.log). Then, run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\upm\upm.db
Then restart dmgtd, and the UPM database engine and monitor should start. If not, then the upm database is most likely corrupt, and will have to be restored from a known good backup, or reinitialized. To reinit, run:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=upm dmprefix=UPM
Please note that reintialising the data would make you loose all the custom Templates and Pollers created.
