05-17-2013 01:07 AM
I have a Cisco Prime LMS 4.1 in soft appliance, all process are running in normal state and suddenly
UPMDbMonitor and UPMProcess are in a Administrator has shut down this server state. Why is this happen?
I start again these two processes and stay in normal state, but some time later they come down (Administrator has shut down this server)
05-17-2013 01:09 AM
The best you can hope for is that the database transaction log has become corrupt. To check this, shutdown dmgtd, then look at NMSROOT\databases\upm. If you see a upm.log in there, delete it (del /f/q upm.log). Then, run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\upm\upm.db
Then restart dmgtd, and the UPM database engine and monitor should start. If not, then the upm database is most likely corrupt, and will have to be restored from a known good backup, or reinitialized. To reinit, run:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=upm dmprefix=UPM
05-17-2013 01:33 AM
Please note that reintialising the data would make you loose all the custom Templates and Pollers created.
