Cisco Prime
aidei0001
Visitor
I keep getting cisco prime alarms in the format Device IP address authentication failed for request from IP address. Please do you know how I can resolve this issue in Cisco Prime.
Many thanks in advance
Mark Elsen
 - Determin the from-ip-address device name following  your a query to your DNS server; if it concerns the Prime server itself then remove the particular-originating device from prime and re-add it; but issue 'verify credentials' first.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Please what credentials should i be verifying?
 - The credentials by which the particular device was entered into Prime
       Beauty and terror
      Just keep going
       No feeling is final
Zain Khan
Level 4
Level 4
Hi Aidei0001,
First edit your device and reenter the SSH credentials then Sync and update most of the cases this works if not
Delete your device and Add again ...if the device imported in bulk then might be miss entered IP adress or SNMP credentials just Delete and Add once again 😉
Zain Khan
https://www.linkedin.com/in/forzain/
