cisco replacement for avaya 2526t switch and 4526t Ethernet routing switch
sgowhar20#20
i need to have two cisco switches which would be equivalent to my existing setup for backup purpose currently i have in my setup avaya ERS 2526t and 4526t switches and SR 1001S nortel router. i need to have cisco devices which would be compatible with this setup.
balaji.bandi
in terms of switche/router you can use below one based on the budget (start with lower end to high level)
Cisco 2960 / 3650 / 9200 / 9300 (for both replacement)
Reference :
https://www.cisco.com/c/en/us/products/switches/product-listing.html#CampusLANSwitches-Access
SR 1001S  -  ISR / ASR  model should be good.
https://www.cisco.com/c/en/us/products/routers/index.html#~stickynav=1
BB
marce1000
 - For more general info's on the Cisco spectrum you can also have a look at :
              https://www.cisco.com/c/en/us/products/switches/switch-selector.html
M.
