Cisco router with 3 spaces between `deny` and `icmp` ?
wo1f
I was configuring deny icmp any any traffic when I realized it was not in the config.
I verified it with do sh run | i deny icmp command as follows:
R1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#
R1(config)#ip access-list extended 100
R1(config-ext-nacl)#deny icmp any any
R1(config-ext-nacl)#exit
R1(config)#
For unknown reason, there are 3 spaces between deny and icmp and caused do sh run | i deny icmp command to fail.
R1(config)#do sh run | i deny icmp
R1(config)#
It turns out the config is actually there with 3 spaces between deny and icmp.
access-list 100 deny   icmp any any
R1(config)#
What was the reason for this behavior?
Is this normal?
Martin L
no, not normal, must be some sort of bug in ios code;  there also is implicit deny all at the end of all ACLs. unless you do permit ip an any.
I've never seen that before, can't think about any root cause of this but a software bug on that release.
