05-23-2019 02:09 PM
Hi friends.
I'm looking for a solution to get IPSec tunnels infos by SNMP form a Cisco RV340 Series Router. I found a Zabbix Template and a MIB for it, but when I run the snmpwalk to the OID we don't have success:
[user@zabbix mibs]# snmpwalk -v 2c -c community 1.1.1.1 .1.3.6.1.4.1.9.9
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs/IP-MIB.txt)
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs/DISMAN-EVENT-MIB.txt)
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs/DISMAN-SCHEDULE-MIB.txt)
SNMPv2-SMI::enterprises.9.9 = No Such Object available on this agent at this OID
I'm trying to use a CISCO-IPSEC-FLOW-MONITOR-MIB and I got this procedure:
https://share.zabbix.com/network_devices/cisco/cisco-ipsec-vpn-discovering
GitHub:
https://github.com/Denis1215/Zabbix/tree/master/Cisco_IPsec_VPN_discovering
Does anybody can help me, please?
Thanks and regards,
Luis Carlos
Solved! Go to Solution.
06-10-2019 11:53 PM
Hi there Lucas,
.tgz is a unix-style compressed archive (.tar + .gzip = .tgz)
you need to decompress the file first and then extract the mib file
I'm custom to a tool like 7zip, but there are many other suitable tools
you do not need to transfer the mib to the RV340 but only install in in zabbix.
the RV340 listens to snmp queries to OID's =numerical references.
the mib is for zabix to convert the OIDs to a textual descriptions
05-31-2019 04:43 AM
05-31-2019 07:32 AM
Hi pieterh, thanks for your reply.
I found this MIB file, but I don´t know how can I convert to .MY files to put in /usr/local/share/snmp/mibs/ on Zabbix Server. Also, I don´t know how do to transfer this MIB files to RV340.
Can you help me, please?
Thanks a lot!
06-10-2019 11:53 PM
Hi there Lucas,
06-11-2019 05:45 PM
Thank you for help friend!
