Cisco SG300-10 can't boot, system light is flashing only
cscosw
yesterday I needed to reset my switch so I hold "Reset"for 30 seconds. From that time switch can't start. If I start switch, system light is flashing only.
Tried to hold reset again, nothing happened.
After about 15 minutes ethernet led turned on (led was green) but after restart switch the led of ethernet doesn't work again and system led flashing..
I tried to console cable, used 115200 but console doesn't show me anything (black window only in Putty).
Any idea please?
marce1000
 - What does  115200  mean ?
 M.
