Cisco SIMS
johnnys
Cisco SIMS is not showing the events sent from the
PIX firewall.The PIX is configured correctly because I ran a sniffer trace and its sends the events to the Netforensics server.
I have added the PIX instances in Netforensics but still no events.
Do I need to ran agents on the PIX, the documenation talks about nf-Agents but I don't understand where they get loaded.
Any suggestions
regds
umedryk
Level 5
Level 5
Yes, you would need the agents on PIX. Pls go to www.cisco.com/techsupport/-----> Click on Guest -----> select Product Support, select VPN and security-----> then click on PIX and then select troubleshooting.
