Cisco Switch Authentication with Microsoft NPS Case Sensitive Issue.
Samuel Caunt
Hi All,
I'm a little confused and i need someone to check over my configuration as i am experiencing a few issues when authenticating to switches using Microsoft NPS. To set the scene I have a number of switches as follows:
1. WS-C3850-24XS 16.6.5
2.  C9300-48T 16.12.4
I have configured both with the following NPS configurations (some details have been removed IP Address and replaced with test ones)
aaa new-model
radius server NPS-01
address ipv4 10.10.10.11 auth-port 1812 acct-port 1813
key REMOVED
radius server NPS-02
address ipv4 10.10.10.10 auth-port 1812 acct-port 1813
key REMOVED
aaa group server radius NPSGroup
server name NPS-01
server name NPS-02
aaa authentication login userAuthentication local group NPSGroup
aaa authorization exec userAuthorization local group NPSGroup if-authenticated
aaa authorization network userAuthorization local group NPSGroup
aaa accounting exec default start-stop group NPSGroup
aaa accounting system default start-stop group NPSGroup
radius-server deadtime 1
line vty 1 4
login authentication userAuthentication
line vty 5 15
I have setup all the relevant NPS policies accordingly and CAN authenticate to them...........however
when i try to authenticate to these switches i require to use either lowercase credentials for login for 1. WS-C3850-24XS or UPPERCASE credentials for login for 2. C9300-48T 16.12.4
1. WS-C3850-24XS 16.6.5 (lowercase only credentials)
2.  C9300-48T 16.12.4  (uppercase only credentials)
Although my AD Account is lowercase If i don't use the right UPPERCASE or lowercase credentials this doesn't appear to authenticate me to the switch although it does if i use vice verse.
What config is missing/causing this and how do i fix it?
Do i need to provide any other details?.
Sam
15 Replies 15
dabitgall21
Hello everyone
¿Can somebody help me please? I need to provide network access to Out-of-domain computers by NPS
i have the following configuration
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
dot1x system-auth-control
radius-server host 10.3.1.12 key cisconps
radius server PCRADIUS-123
address ipv4 10.100.1.12 auth-port 1812 acct-port 1813
key shared24
On port i have this configuration:
interface GigabitEthernet1/0/9
switchport mode access
authentication host-mode multi-auth
authentication port-control auto
dot1x pae authenticator
spanning-tree portfast
I can provide access to network by NPS but just for Computers within the domain, now i need to provide the access to a guest network in Out-of-domain computers.
I hope you can help me, regards.
