CISCO SWITCH IE9320
malcomx
I have SCADA PTP Profiles, Default and Power. We would like to know if one CISCO Switch can be configured on both profiles, i.e. some ports on profile Default and some ports on profile Power, or if the Switch can only be configured on one Profile?
are you talking about configuring interface profiles ('ptp profile default' and 'ptp profile nondefault') ?
Ruben Cocheno
@malcomx
The PTP profile can only be set globally (one profile per switch).
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
