Cisco to Mikrotik Trunk Configuration
JI-RAJU
Plz See the Attachment below
2 Accepted Solutions
Mark Elsen
 - Do you also have a question and or problem description ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
setyadwi
Maybe you can explain further what the problem is to get help.
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Sorry For delay reply. I'm sorry It's done. I waited long time but i didn't get a reply. But finally it works.
Thanks to u both. OK, My question was Router-on-a Stick between Mikrotik to Cisco L3 SW.
1. Linksys L2 SW: Individual Port individual VLANs
1. Cisco L3 SW: VLAN 2: 162.16.2.0/29
                          VLAN 3: 162.16.3.0/29
                          VLAN 4: 162.16.4.0/29
2. Mikrotik: Ether5 will be the Trunk port.
It's working fine but if u you have any better solution then tell me Plz:
Solution: Note: This is for beginner i'm also a beginner, i post this from my real experience.
Linksys Layer 2 Switch configuration:
Step1:Create Different VLANs
          switch>conf
          switch>vlan database
          switch>vlan 2.......
                                    .....24
          after create VLANs 2 to 24 then assign port for VLANs and also create Native VLANs 999 in same way for trunk port.
         switch> conf
        switch>int ethernet e2
       switch> switchport mode access
      switch>switchport access vlan 2.........
                                                     .................24
Then...... switch>conf
              switch>int g4
              switch>switchport mode trunk
              switch>switchport trunk native vlan 999
              switch>switchport trunk allowed vlan add 2-24
Step 2: Cisco L3 Sw: SVI (Switch Virtual Interface )
                                  switch-L3-SW>conf
                                  switch-L3-SW>vlan database
                                  switch-L3-SW>vlan 2......
        .......24
                                  switch-L3-SW>conf
                                  switch-L3-SW>int vlan 2
                                  switch-L3-SW> ip address 162.16.2.2 255.255.255.248
                                  switch-L3-SW> no shut......................continue for all VLAN
Trunk: Gigabit ethernet 25 for Trunk port (Trunk Port For L2 G4-L3 G25)
               switch-L3-SW>conf
               switch-L3-SW>int g25
               switch-L3-SW>switchport mode trunk
                switch-L3-SW> switchport trunk allowed vlan add all
                Create another Trunk for Mikrotik link in same way above suppose int g26 is trunk
This connection is OK between L2 to L3. Now L3-Mikrotik
Step 3: Cisco Layer 3 Sw- Mikrotik (Connect G26 to Mikrotik ether5)
In mikrotik delete all default setting
Ether1: Set ISP IP and Gateway (If anyone problems with this then see the details in google )
Ether 5: In Mikrotik left pane see the Bridge - then click on plus (+) and create a new bridge like bridge1
             then.. bridge-port-add add ether5 to bridge 1
                       bridge-VLANs add VLAN ids and current tag port (e.g- 2, ether5,bridge1)
And create same vlan in mikrotik in interface-VLAN and set ip address for every vlan
finally masquerade and vlans filtering enable. Done
Everything is working fine till now. any suggestion .
setyadwi
