Cisco RV345 Dual-WAN with Google WIFI
Assafshp
I have a dual-wan cisco RV345 router which is connected to two modems. I use it for Internet failover (dual WAN plus cellular modem). I tried to connect the Google wifi for it and I can't make it to work. The two modems are configured as bridge and the RV345 router has the PPPoE settings enabled. If I connect with an ethernet cable to the RV345 router everything works well. But, when I connect the google WIFI point to the router I have no internet connection through the WIFI connection. I will appreciate any help, I assume I need to change some settings in the cisco RV345 but I can't understand whatinternet.png
balaji.bandi
we need more information on how your configuration for the Google Wifi ?
Looks like You have 2 different IP address for Wifi and Ethernet - when Google Wifi router connected to RV345, RV give different Address for Google Wifi, what IP address you get when you connect to google wifi from a client ?
Looks for me ( assuming that) you need a static route entry for the Wifi address space towards google ethernet Interface or IP address
also, provide what is the IP address working when you connect to ethernet?
what is the IP address you get when you connected to wifi (which is not working ?>)
BB
