10-12-2015 07:48 AM
Hi everybody,
I need to read several values periodically from a cisco switch (Catalyst 3750) including SFP's module temperature, voltage, Rx power, and Tx power.
For the first three parameters, everything is fine. I can read the values and they change over time.
However, for the Tx power, the value is constant! it doesn't change over time at all! I read it using both SNMP and CLI, and the value was constant over three months!! (I read it once every 5 minutes). The Tx readings of different interfaces are different. But again: the value for each interface doesn't change over time.
Any hints? what could be the problem? how it can be solve?
Thanks a lot in advance.
Best regards,
Hani
10-12-2015 11:20 AM
what is the exact problem you are having? (other than txlevel == txlevel)
is it possible the SFP is sending the same power level and it is not changing?
under what circumstances would you expect it to change?
this article indicates the tx power cannot be changed , but may vary from device to device.
https://supportforums.cisco.com/discussion/10834446/sfp-output-power-control
hope this helps,
Dan
10-13-2015 01:29 PM
