Cisco View question
6tschraml
Level 2
Level 2
How can I find out which version of the following CiscoView packages are installed on a LMS 2.5.1 server:
SwitchAddlets
CLIParser
Entity
These files are prerequisites for a couple of device packages but I don't find them in the package update list. An attempt to install them together with a Cat6k package has only installed the Cat file - but not the three files in question. Now I would like to check manually if I have the latest versions of these files on my server but I don't find them anywhere.
Thanks in advance
Thomas
David Stanford
You'll want to open the Chassis View window and once it is displayed you then select About in the upper right corner. there will be a list of installed device packages that you can highlight and scroll down through to see versions
... works as described. Thank you.
Thomas Schraml
