Cisco voice Gateway 2851
itaomandc_2
Hello Friends,
I want to Know is the voice gateway 2851 is supported in LMS 3.1, Can anybody advice me for the SNMP walk tool .This device is not been discovered by CS
5 Replies 5
Joe Clarke
What is the sysObjectID of this device?
From where i can find the oject ID
You can use the SNMP Walk tool from Device Center to poll the OID "sysObjectID".
Hello
When i do snmp walk from Device Center it says me that the device is not reacheable,put the correct snmp string or sysOID,
it is not showing me any OID in the output
If DC says the device is unreachable, then the SNMP credentials you entered must be incorrect, or there is a firewall blocking SNMP to the device.
