Use SNMP to monitor the power supply status of stacked switches
josephqiu
Does anybody know how to use SNMP to monitor the status of the internal power supplies of a group of stacked Cisco 3750 switches?
The switch stack has three 3750-48PS-E switches inter-connected by Cisco StackWise cable. IOS ver 12.1(19)EAlc. A single IP address is used to identify the switch stack. Every time I poll the OID chassisPs1Status (1.3.6.1.4.1.9.5.1.2.4.0 in CISCO-STACK-MIB), I only got the status for the Master switch of the switch stack. Is there any way to poll the power supply status of other switches in the switch stack?
Thanks a lot!
krozier
Hi Joseph,
You are going to need to walk CISCO-ENVMON-MIB for the TEMP/PowerSupply/FAN status of 3750's in stacks. Here are some specific OID's:
1.3.6.1.4.1.9.9.13.1.4.1.2 ciscoEnvMonSupplyState
1.3.6.1.4.1.9.9.13.1.5.1.2 ciscoEnvMonSupplyStatusDescr
I have checked this in Solarwinds on my 3750 stack and it works perfectly. Hope this helps
Kersean Rozier
6 Replies 6
rmushtaq
Level 8
Level 8
Without having individual ip add assigned to the stack switches, don't think you can poll them for the status.
krozier
Hi Joseph,
Kersean Rozier
Hi Kersean
Your tip works!!!
The OIDs work for me are:
ciscoEnvMonSupplyStatusEntry.4.1003 --> switch #1 PS
ciscoEnvMonSupplyStatusEntry.4.2003 --> switch #2 PS
and so on...
Thank you so much!
I take it if you have 3 switches then the following is correct ?
ciscoEnvMonSupplyStatusEntry.4.3003 --> switch #3 PS
Yes, it's correct. You can have up to 9 switches in the stack.
Sorry to refresh such an old topic - but I am stuck with exactly this: Monitoring power supplies of a stacked Cisco Catalyst 3750-E.
I'm using the exact same OID's as described, but the problem is, the information shown on the SNMP output is not correct.
This morning, a power supply of the first switch failed and switched to RPS. Here the information I got on SNMP:
snmpwalk -v 2c -c public 192.168.1.50 1.3.6.1.4.1.9.9.13.1
SNMPv2-SMI::enterprises.9.9.13.1.1.0 = INTEGER: 13
SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.1006 = STRING: "SW#1, Sensor#1, GREEN "
SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.2006 = STRING: "SW#2, Sensor#1, GREEN "
SNMPv2-SMI::enterprises.9.9.13.1.3.1.3.1006 = Gauge32: 41
SNMPv2-SMI::enterprises.9.9.13.1.3.1.3.2006 = Gauge32: 40
SNMPv2-SMI::enterprises.9.9.13.1.3.1.4.1006 = INTEGER: 59
SNMPv2-SMI::enterprises.9.9.13.1.3.1.4.2006 = INTEGER: 59
SNMPv2-SMI::enterprises.9.9.13.1.3.1.5.1006 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.13.1.3.1.5.2006 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.1006 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.2006 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.4.1.2.1060 = STRING: "Switch#1, Fan#1"
SNMPv2-SMI::enterprises.9.9.13.1.4.1.2.2059 = STRING: "Switch#2, Fan#1"
SNMPv2-SMI::enterprises.9.9.13.1.4.1.3.1060 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.4.1.3.2059 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.1059 = STRING: "Sw1, PS1 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2060 = STRING: "Sw2, PS1 Normal, RPS NotExist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.1059 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.2060 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.1059 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.2060 = INTEGER: 2
As you see, both PS1 (for both switches) are appearing normal. It doesn't even recognize RPS:
The first switch's power supply died and now the cable is disconnected. LED's of the power supply are out. And still: The switch happily announces by SNMP it's power supplies are up.
Is this a known bug? If yes, has it been fixed?
Model  WS-C3750E-48TD
Firmware 12.2(37)SE1
