Cisco VTY Session Question
Community,
Can someone take a look at the following vty line configuration and let me know why I can't open more than one session
line vty 0
exec-timeout 60 0
login authentication vty_access
transport input all
line vty 1
exec-timeout 60 0
no exec
transport preferred none
transport input all
line vty 2 4
exec-timeout 60 0
transport input all
line vty 5 15
exec-timeout 60 0
no exec
transport input all
Richard Burts
I see issues that prevent some of the vty lines from accepting sessions but not enough problems to account for being limited to a single session. on vty 1 and on 5 to 15 you have configured no exec. This prevents any session from being established.
I assume that the session you establish is probably on vty 0. I do not see what would prevent additional sessions on vty 2 through 4. Perhaps there is something in vty_access which is having this impact? We need to have more information to be able to come up with a good explanation. At a minimum we will need to see the aaa parts of the config. Perhaps the output of show line might also be helpful.
Rick
Rick
Richard Burts
Rick
Rick
Hi Richard,
Thanks for getting back to me.
The problem was 'no exec'
Cheers
Carlton
Carlton
I am glad that you have resolved the issue and that my suggestion was helpful. Thank you for using the rating system to mark the question as answered.
Rick
Rick
I was going to say the same earlier. By default vty login will use the next avaialble vty line. Since you always had line 1 avaialble but essentially unusable, you could not establish a second vty.
I believe you could have hacked around that by specifying the line number when inititaing a login. e.g. telnet  3003 as specified in this old thread.
