05-09-2022 02:13 AM
I am not able to configure a CISCO camera over wifi in packet tracer. I am only able to connect them to the server if they have a Fast Ethe output.
Any ideas, advice or help?
Thank you very much
05-09-2022 02:34 AM
Attach you .pkt file here. You need to zip it first. Easier to help.
05-09-2022 02:39 AM
05-09-2022 03:12 AM
05-10-2022 12:14 AM
Oh! It works!! Thank you so much!! Its connected to the Router. But i have one more question, how can i connect the wireless router to the server? Because the camera its configured with 1.1.1.1 but im not able to see the camera in the server desktop webpage.
Thank you!
05-10-2022 12:40 AM
what instructions are you following ? The server has no default gateway, and the wireless router is not connected to anything on the Internet side...
05-10-2022 03:35 AM
On the file attached I have connected the router on the infrasctructure in the simpler way possible. The server has the IP address of 1.1.1.1 and I put the wireless camera as 1.1.1.100.
However, you can connect the router somewhere else but keep in mind that if you plug the wireless router in another router you need to add static or dynamic routing on others routers.
It is also interesting enable DHCP server on the server and put all camera in DHCP.
