Cisco Works Error
lalit
Hi ,
I have a Cisco work server and i am facing problem with the Netconfig job failure.It fails the job with following error.
" ERROR:RME_CDL1032:Synchronization of the running configuration before deply,has failed" and also i am seeing the following error as " cm0012:Unable to create new version on archive $1 " Action : Check if disk space is available and directory has required permission.
LMS version  : 2.6
RME Version : 4.0.5
Please let me know if you have any idea on this error.
Thanks in advance
Thanks & Regds,
Lalit
Svetlana Radzevich
CM0012 error is a bug - "CSCsh39475    ConfigMgmt CM0012: Unable to create new version on archive". The patch is posted on CCO.
