Cisco Works - Export CM Topology Map to Visio
dimzaaaaa
Can anyone explain, how to export CM topology map to Visio without losing map integrity. Here are the relevant versions of the programs in question:
Cisco Works:
1.CM4.0UnlimitedPurchasedNever
2.DFM2.0UnlimitedPurchasedNever
3.IPM2.6UnlimitedPurchasedNever
4.RME4.0UnlimitedPurchasedNever
MS Visio 2007. Thanks.
Joe Clarke
Visio 2007 is not supported (only up to Visio 2003 has been tested).  There will always be a need to cleanup the map after exporting it.
