Cisco works LMS 3.0.1 cannot archieve configuration for cisco 3000 series vpn concentrator
samir_1976
Hi All,
Our problem is, we have Cisco Works LMS 3.0.1. cannot archieve configuration for cisco 3000 series vpn concentrator.
Any help would be greatly appreciated.
Thanks in advance.
Samir
Then RME will not be able to fetch the config.  RME will only use HTTPS for VPN 3000 devices.
Joe Clarke
Make sure you have filled out all of the HTTP/HTTPS credential data in DCR for these devices.  RME will only use HTTPS to fetch VPN concentrator configurations.
Hi ,
But we are not using any HTTP/HTTPS credential for device.
Samir
Thanks for your kind reply.
Samir
