cisco works LMS with Read Only community string
dinesh joshi
Can cisco works LMS 3.2 collect devices inventry details with read only string configured in router or we need to confiure read write
string in cisco router. What is priveledge level of username password need to configure in devices.
Dinesh Joshi
AFROJ AHMAD
Hi Dinesh,
Yes you are right  for cisco works to collect the inventory of the devices it needs Only  READ ONLY Community  string.
Read write Community string is requried in case you want to make any changes on the device using cisco works .. for E.g you used NET-CONFIG
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Dinesh,
Afroj
thanks Afroj for your reply
