02-11-2005 12:41 PM
How do I get Campus Manager to update the "Logical Discrepency" report? Specifically, CM shows "VLAN mismatches" that are old.
Solved! Go to Solution.
02-14-2005 12:08 PM
Vince--thanks for the update and feedback. If the answer provided solved your problem, please take the opportunity to mark it as such. This helps others who may have the same problem, zero in on the correct answer.
02-11-2005 03:17 PM
ANI rediscovery should fix this. What OS/CM/IDU versions are you running?
02-11-2005 03:21 PM
Windows 2K
CM: 3.3 IDU: 9.0
02-11-2005 03:42 PM
I couldn't find any specific bug, or any specific instructions on Cisco.com. However, IDU 11 is out, perhaps try upgrading to the latest IDU.
By default ANI rediscovers your network every four hours, unless you've changed this. Have you corrected the errors and let ANI rediscover the network?
02-11-2005 03:26 PM
I ran re-discovery today, but still see old 'false' mismatches.
02-11-2005 03:44 PM
Weird--I'll do some more research and get back with you. Maybe somebody else will chime in with a suggestion.
02-12-2005 04:56 PM
Vince--To reset your Logical/Physical Discrepancy Reports do the following:
Goto CW2K>Campus Manager>Administration>Network Discrepancies and deselect the discrepancies you'd like to reset (I chose all) > Apply
Force CM to perform a discovery. When it's finished, your discrepancies should be filtered out (in my case, since I deselected everything, my discrepancy reports were empty).
Return to CM>Admin>Network Discrepancies
Select the network discrepancies you'd like CM to report. Then force CM to perform another discovery. Now all your reports should have current date/times.
Steve
02-14-2005 11:28 AM
Hey, that seems to have did the trick.
Thanks for the info.
02-14-2005 12:08 PM
