Cisco Works-QPM disk space shortage
Mohamed Sayed
hi all,
I am running QPM (Quality of services Policy Manager) Version: 4.1(6) and I cannot run the historical reports and I found this log:
Disk space shortage: You cannot Create or Edit Tasks; Running Tasks will be stopped
how can I solve this issue ???
I appreciate your kindly support
AFROJ AHMAD
Hi Mohamed,
check the below link , hope it will help:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_qos_policy_manager/3.1/user/guide/KKtrbl.html#wp1030325
One step that should be done after cleaning up the disk space is to restart
the services.This should solve the problem.The error message should go away
after a services restart, provided you have enough disk space which you
have selected during installation.
For example , If you have chosen to have 40% free disk space for
monitoring during install , the 40% of the disk space should be available
after the cleanup.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi AFROJ,
thanks for your kindly support.
I read it and I donot know how to do some steps:
1- locate the qpm.cfg file under mdc\qpm\config >>>> from where I found this file.
2- how can I do the "cleaning up the disk space"
I appreciate you.
Hi AFROJ,
any update please?
look under :
NMSROOT\CSCOpx\mdc\qpm\config
NMSROOT is the directory where this softeare is installe  like c:\program files
I have not much worked on Qpm .. But look for logs or some files which is of no used and delete them.
checkif you have any files like  JAVA_PID. HPROF files  under  NMSROOT\CSCOpx  and NMSROOT\CSCOpx\mdc\tomcat  , if there are any such files ..just delete them.
Thanks-
Afroz
