Cisco Works Report Error
arun.sasidharan
HI All,
While I am generating any reports from the LMS , I am getting following error "Report Could not be store" and if we press enter it will show the details in the screen.But able to download in pdf or xls format.
6 Replies 6
Joe Clarke
What version of RME is this?
Version is RME 3.0, Not even RME i am facing problem in Comon Services , DFM etc while generating report.
The original screenshot is from RME. And this is not RME 3.0. What are all the versions of the LMS applications you are using?
Sorry Clarke, bymistaken i given that version.
pls find the attached file for all versions.
This appears to be related to CSCsa82338 which is fixed in RME 4.1.1 (part of LMS 3.0.1). You can download the LMS 3.0.1 update from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 .
