10-22-2009 06:54 AM
Hi everyone! I'm having an issue with the right click menu on devices in Topology Services in Campus Manager 5.2. When I right click the device the whole menu comes up, but I can only run a couple of the items. The ones that don't work are: device attributes, port attributes, VLAN report, both RME choices, device dashboard, both IPM choices, both DFM choices, cisco view, troubleshoot, device center, and VSM. All the other menu items work, but it is annoying not having the right click option for cisco view especially. Any ideas?
Solved! Go to Solution.
10-22-2009 09:04 AM
Hmm, the bug appears to be written incorrectly. The report had 1.6.0_13, and encountered the problem. So it appears to affect 1.6.0_13 and higher. Try 1.6.0_11.
10-22-2009 07:50 AM
What do you mean they don't work? What errors do you get trying to run them? What version of Java Web Start are you using?
10-22-2009 08:19 AM
Thats the wierd part, they don't do anything... I get no error message or any indication that something is wrong. When you left click to select the item, the menu just dissapears. I am using Java 6_16.
10-22-2009 08:31 AM
I believe that is the problem. There is currently a bug in Java greater than 1.6.0_13 (CSCsz16391). The root of the problem is a change in the Java VM, and we are currently working with Sun to get it fixed. Try downgrading Java to 1.6.0_13 or lower, and see if this problem goes away.
10-22-2009 09:02 AM
Just uninstalled 16 and loaded 13... Same problem...
10-22-2009 09:04 AM
10-22-2009 09:44 AM
11 works! Thanks for the help!
