CISCO1921/K9 terminal server problem
Jan Rolny
Level 3
Level 3
i have router 1921/k9 configured as terminal server with HWIC-8A card.
Problem is that one of serial lines where I have ASA connected (to console) is trying authenticate all the time to ASA.
Output seems like this:
1921#host asa1
Trying asa1 (1.1.1.1, 2005)... Open
Username:
Password: ********************************************************************************************************************************
Username:
Username:
Username:
and so on .....
Problem is solved after reboot of router. I tried reset line and it does not work. I would like to stop this flood authentication but I have no idea how. Is it possible that it is HW failure or bug?
Thanks for any advice.
Jan
Richard Burts
Jan
Do you have "no exec" configured on this line where the problem happens?
Perhaps if you post the config we might find something to suggest.
Rick
Rick
Hi Richard,
thanks for reply. I cannot provide you all the confirg but i will cut interesting part what would interest us:
no ip domain lookup
ip domain name taccess.com
ip host cat3750-1 2003 1.1.1.1
ip host cat3750-2 2004 1.1.1.1
ip host asa1 2005 1.1.1.1
ip host asa2 2006 1.1.1.1
ip host ace1 2007 1.1.1.1
ip host ace2 2008 1.1.1.1
ip host acs 2009 1.1.1.1
ip host fw-int-1 2019 1.1.1.1
ip host fw-int-2 2020 1.1.1.1
ip host cat2960-1 2021 1.1.1.1
ip host cat2960-2 2022 1.1.1.1
ip host fw-vpn 2023 1.1.1.1
ip host ntp 2001 1.1.1.1
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Async0/0/0
no ip address
encapsulation slip
interface Async0/1/0
no ip address
encapsulation slip
interface Async0/0/1
no ip address
encapsulation slip
interface Async0/1/1
no ip address
encapsulation slip
interface Async0/0/2
no ip address
encapsulation slip
interface Async0/1/2
no ip address
encapsulation slip
interface Async0/0/3
no ip address
encapsulation slip
interface Async0/1/3
no ip address
encapsulation slip
interface Async0/0/4
no ip address
encapsulation slip
interface Async0/1/4
no ip address
encapsulation slip
interface Async0/0/5
no ip address
encapsulation slip
interface Async0/1/5
no ip address
encapsulation slip
interface Async0/0/6
no ip address
encapsulation slip
interface Async0/1/6
no ip address
encapsulation slip
interface Async0/0/7
no ip address
encapsulation slip
interface Async0/1/7
no ip address
encapsulation slip
line con 0
logging synchronous
line aux 0
no exec
transport preferred telnet
transport input telnet
transport output telnet
telnet transparent
stopbits 1
speed 38400
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 0/0/0 0/0/7
login authentication lines
no exec
telnet transparent
flowcontrol software
line 0/1/0 0/1/7
no exec
telnet transparent
line vty 0 4
exec-timeout 120 0
logging synchronous
transport input ssh
line vty 5 31
exec-timeout 120 0
logging synchronous
transport input ssh
Jan
