cisco2811 fan not rotating causing the configuration to malfunction ?
bombey
Cisco 2811 fan stopped working. I found that the configuration has changed. Device malfunction And I found that one of the fans stopped working. Is it possible that this is affected by the fan stopping?  thank you. bey's
M02@rt37
Hello @bombey
Fan failure can indeed impact the device's performance and potentially lead to malfunctions. The fans in networking equipment like the Cisco 2811 play a crucial role in maintaining proper cooling for the components. If a fan has stopped working, it can lead to increased temperatures inside the router, potentially causing overheating issues.
Changes in configuration might not directly be related to the fan failure unless the router's temperature has triggered automatic adjustments or shutdowns due to overheating.
Best regards
thank you so much
