11-15-2005 12:24 AM
I have the following problems.
Archive Management
There are a lot of devices that are not updated. The msg is the following.
Telnet acces is not correct, i am sure that the value is correct.
Campus Manager
My campus manager is in running status from the 04-11-2004.
Even afther a reboot it will not stop.
SNMP reports will stop displaying afther 2 days
If i click on user tracking Acquisition it will take forever until the page is displayed. When i see the page there is NO information.
11-15-2005 06:54 AM
What version of CiscoWorksgreat4meexcept4DFM are you running? What is the server OS version?
11-16-2005 12:30 AM
All the latest version's. I have never seen so buggy tool like ciscoworks.
If i click on usertracking admin it will take ages to show me the page. Syslog e-mail stop 6 weeks ago. Config from switches will not be pushed to CW. (credentials are good)
I am totaly lost in CW
11-22-2005 08:17 AM
Same same. It's NOT working.
For archive management, you need to first check device credential. Make sure all device pass credential check. If fails, do a device credential export and manually exam the login and password.
For the UT, do you have seed device configured?
