ciscoUnifiedComputingMIB
HEATH FREEL
Level 7
Level 7
Trying to get the PSU status and getting odd responses. Is there a table that list what the responses mean to a specific query.
I have a number of C series servers. I use SNMP to index the PSU and tell me the status.
Server 1.
PSU Index = 1
PSU Index = 2
PSU1 status = 1
PSU2 status = 5
CIMC tells me that PSU2 has "input lost". That makes me assume that 5 = down or no power.
Server 2.
PSU Index = 1
PSU Index = 2
PSU1 status = 5
PSU2 status = 5
CIMC tells me that both are Present/ Normal... This tells me that 5 does not mean down....
Any help would be appreciated as I am unable to find any documentation on that the responses actually mean.
Allen A
I normally use the SNMP object navigator, however it doesn't seem to be returning any info about the OIDs for this MIB.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.719
What OIDs are you using?
-Allen
I am using the following to get the PSU Identifier
cucsEquipmentPsuId - 1.3.6.1.4.1.9.9.719.1.15.56.1.5
Then the following to grab the operational state.
cucsEquipmentPsuOperState - 1.3.6.1.4.1.9.9.719.1.15.56.1.7
I believe the issue may be that the state does not represent power present, but rather that it is a working power supply, whether it is receiving power or not.
Maybe a bit late but could be worth looking at Bug CSCun73331 : "EP: SNMP PSU Table values are not consistent after AC Power cycle"
I was having a similar issue and the workaround did it for me.
