CiscoView Device Updates
Ian Beck
Running the latest updates for CiscoView, but the Cat3560 fails to load with Dtshare not up to date. System is upto date with all other packages.
Any ideas ?
C:\Users\IanADM>d:\ciscoworks\bin\psucli -p cvw -install -src d:\psu_download\cv
Services might be restarted, as a result of install operation
Would you like to continue ? ( Press y or n )
y
Proceeding with install..
Loaded psu.properties..
INFO: Installing for cvw
Locking the package repository...
got all packages Repository
Checking Dependencies...
WARNING: Cat3560(14.0):Consistency check failed for base package DtShare
WARNING: Nexus5000(4.0):Version 4.0 already installed
WARNING: SwitchAddlets(1.34):Version 1.34 already installed
WARNING: Nexus7000(6.0):Version 6.0 already installed
There are no Packages to be installed
Released the Lock...
No package(s) to install for CiscoView
alain-bhend
Hi Ian,
I have the same problem with installation of package for Cat3750.
I have seen in the readme files for Cat3560 and Cat3750 that both need to have installed the DtShare V1.10 (DtShare.cv50.v1-10.zip) first.
On my CiscoWorks there is actually installed DtShare V1.9, but it seems that there is no DtShare V1.10 ready to download via Common Services - Software Center - Device Update. Also the manually download of the packages via CLI gives me only the DtShare V1.9.
So I assume that we have to wait until Cisco makes the DtShare V1.10 available.
Alain
alain-bhend
Hi Ian,
If you are running also LMS3.2 then check again the device update packages.
I have downloaded yesterday evening the actual package for Cat3750 and this package I was able to install. For the Cat3560 there is also a new package dated in September.
Try again to install this new package, probably it's also installable.
Alain
