Synchronize archive
dominoforever
Hey,
I would like to backup the config of all devices but I have an error whan I launch the Sync Archive.
See the error below:
The following is the status of your Sync Archive job:
Job ID         : 1637
Status         : Job Failed(1)
Description   : test sync
Details       : http://ciscolms.domain.local:1741/rme/DcmaJobDetails.do?jobid=1637
Start Date and Time : Mon Aug 08 11:02:14 CEST 2011
End Date and Time   : Mon Aug 08 11:03:23 CEST 2011
RME Server Name/IP : ciscolms.domain.local
Execution Summary
Pending         : 0
NotAttempted     : 0
Successful       : 0
Failed           : 1
Partial Success : 0
I don't know if I forgot something, could you please help me?
Kind regards,
Sébastien
45 Replies 45
AFROJ AHMAD
HiSébastien,
Kindly send me the below information:
--output of pdshow
Enable the Debugging for RME > Admin> system preferences >Appication log level settings >Archive Management
--clear the dcmaservice.log
--now Re-run the job again..
---collect the dcmaservice.log and Job folder and send me that as well..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Sorry I forgot to paste the result of the job.
1.192.168.254.1VLANRUNNINGAug 03 2011 15:06:34TELNET: Failed to establish TELNET  connection to 192.168.254.1 - Cause: connect timed out. VLAN Config fetch is not  supported using TFTP. Could not detect SSH protocols running on the device VLAN  Config fetch is not supported using RCP.
2.192.168.254.1PRIMARYRUNNINGAug 03 2011 15:05:40TELNET: Failed to establish TELNET  connection to 192.168.254.1 - Cause: connect timed out. PRIMARY-RUNNING config  Fetch Operation failed for TFTP. Could not detect SSH protocols running on the  device Failed to fetch config using RCP.Verify RCP is enabled or not.
Afroj, I have LMS 4.0. Which module do I need to enable in the discovery logging configuration?
Kind regards.
Go to
Admin > System: Debug Settings > Config and Image Management Debugging
selcect Archive Management..
Afroj
I can't clean the file dcmaservice.log, which process do I need to stop and start? ConfigMgmtServer?
Seb
Browse to the below directory and run this cmd:
NMSROOT\log>logrot_trunc dcmaservice.log
Afroj
I restarted the service ConfigMgmtServer and then it was fine. How can I send to you the log file?
Seb
I modified the Default Credential Set with Standard, SNMP et HTTP Credential but I always have the same errors.
Like this :
How can I fix this?
Hi seb,
You need to attached the dcmaservice.log file along with the Job folder of the Last job that you have ran for the Sync Archive..
Afroj
See the log file attached.
Thanks.
I tested credential verification and I juste habe Read Community which are good.
Why for the others I have No Value To Test?
Hi seb,
Are you using any Custom Prompts on your device ?
Kindly attached the screen shot when you do a telnet or ssh to the device ..
Afroj
Hi Afroj,
What do you mean for Custom Prompts?
Hi Afroj,
did my previous email help you?
Thanks.
Hi Seb,
Send me this file : TACASPROMPTS.ini    (location :NMSROOT\objects\cmf\data)
Afroj
