Ciscoview patch installation problem
ravirepaka
I have cisco view 5.5 and want to monitor the 6509-E (IOS) .But all the 9 cards/modules are showing as unsupported.
To come over this probelm I decided to install the latest patches 19.1 ,but when I try to install that I am getting the error as minor version are incompatiable
Enclosed the doc which shows the error.If any one have the answer to this problem,please reply.
Thanks in advance
nhabib
Level 9
Level 9
If you click on Installed packages, what version of CLIParser do you see listed?
Looks like you need version 1.4
Yep that's what we can interpret from the error,It looks like I need CLIParser version 1.4,I have CLIParser 1.3 version installed .But Unfortunately I could not find the CLIParser V1.4 on the Cisco Site.
Can any one send me a link if you guys find 1.4 version
Thanks In advance
You can download the CLIParser 1.4 package from the following URL:
http://www.cisco.com/cgi-bin/tablebuild.pl/cview50
do a "find" on 1.4, and it will take you right to it.
Thanks for the reply,Got the same from Cisco TAC
