Ciscoview supported modules help.
laerciotobias
Level 2
Level 2
Hi all
the page bellow where shows the supported devices is not working and i need to know if the WS-X4612-SFP-E is supported at the Ciscoworks 4.1
http://www.cisco.com/pcgi-bin/Software/CiscoView/cvplanner.cgi
Ps - i am using Ciscoworks 4.1 and i am using the defult ciscoview version.
Thanks.
Marvin Rhoads
If you do a device update to your LMS software (to the current version 24.0 for Cat 4000), you will have support for those modules. Admin > System > Software Center > Device Update is the menu path to do that.
Here is a link to the readme for 24.0. It states, in part:
1/24/2012
Cisco Cat4000 Family Switches running IOS, Incremental Installation Release 24.0
Supported for:
* CiscoView 6.1.6 and above for CiscoWorks
WHAT IS NEW?
This Cat4000IOS(24.0) release provides support for the following devices and modules:
* WS-C4928-10GE
* WS-X4712-SFP+E
* WS-X4612-SFP-E
* WS-X45-SUP7L-E
* WS-X4748-UPOE+E
* WS-X4748-RJ45-E
Marvin Rhoads
1/24/2012
Supported for:
WHAT IS NEW?
* WS-C4928-10GE
* WS-X4712-SFP+E
* WS-X4612-SFP-E
* WS-X45-SUP7L-E
* WS-X4748-UPOE+E
* WS-X4748-RJ45-E
Marvin,
Thanks again.
I installed the cv pack and everything is working fine.
