CIscoWorks add Device Type OID
neil.tidcombe
Does anyone know if it's possible to add a device type and OID? Currently running common services 3.0.5 and would like to add the device type for the 2960 range of switches
miheg
Level 5
Level 5
Yes,
Under common services click "Software Center" and then "Device Update".
You will be presented with the list of available device packages
Cheers,
Michel
David Stanford
Are you asking if the device is supported or just wanted to know how to add it?
The OID's for supported 2960's are:
1.3.6.1.4.1.9.1.929
1.3.6.1.4.1.9.1.928
1.3.6.1.4.1.9.1.927
I want to know how to add the 2960 and respective OID.
Although according to the documentation the 2960 should be supported in version 3.0.5 CWCS
