CiscoWorks:Alerts/Reports showing same device with multiple interfaces
raza555
Level 3
Level 3
HI,
I have getting alerts in RME Collection Status that Config Archieve- Failed to collect are 171, when I click the 171 devices, the list of devices appears and the list shows the few device multiple times with its different ip addresses. But if I search for that particular device in Object finder, its only displaying it only 1 mgmt interface IP address and that’s the only IP address I have entered when I added this device in CW.
Also Device discovery is turned off. All devices have been added manually via bulk import. Whenever I also generate a report, I found few device displayed multiple time with different IP addresses.
I don’t know why CW is behaving like this.
We are managing 3500 device and this type of wrong information are nighmare.
Please advice how I can solve this problem.
I am using
RME: 4.3.0
CS : 3.3.0
LMS: 3.2
DFM:3.2.0
THANKS
Joe Clarke
If the devices were added manually, then the bulk import file must have listed the devices by different IP addresses (or devices already existed in DCR by different IPs).  If you go to RME > Devices > Device Management > Alias Devices, you should be able to resolve the aliases there.
