CiscoWorks Apache Issue
eng.mshari
Community Member
Good day,
I have an issue with our CiscoWorks. After I applied several patches to the CiscoWorks, the apache services wouldn't start. Every time I try to start "CiscoWorks Web Server" service, it gives me "Windows could not start the CiscoWorks Web Server on Local Computer.".
Is there anything I can do to solve this issue.
Thank you in advance
14 Replies 14
AFROJ AHMAD
Hi Abdul,
Try to Unregister and Register the Apache service :
To Unregistered:
pdreg -u Apache
To registered :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d TomcatMonitor
Change the C:\progra~2  with your Cisco works Installed Directory.
I hope this will help
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thank you fvery much or your replay,
I did what you told me, but it didn't solve the issue.
This is what I got:
C:\Documents and Settings\f93151>pdreg -u Apache
C:\Documents and Settings\f93151>cd C:\Program Files\CSCOpx\MDC\Apache\bin
C:\Program Files\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\Program Files\CSCO
px\MDC\Apache\bin\Apache.exe" -f "-d C:\Program Files\CSCOpx\MDC\Apache -D SSL"
-d TomcatMonitor
Files\CSCOpx\MDC\Apache\bin\Apache.exe"" was unexpected at this time.
Any sugestion?
Hi Abdul,
First thing : Apache service should be on MANUAL.  change the startup type
run the below command:
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -l Apache
Output should look like below :
        Process      = Apache
        Path         = C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe
        Flags        = -d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL
        Startup      = y
        Dependencies = TomcatMonitor
In your case I think Apache is not registered , check the location of Apache.exe . It could be located under ::
"C:\Program Files\CSCOpx\MDC\Apache\Apache.exe.  if this is the case..
then try to register it again :
px\MDC\Apache\Apache.exe" -f "-d C:\Program Files\CSCOpx\MDC\Apache -D SSL" -d TomcatMonitor
Afroz
Thank you very much for your replay,
I did it, but it didn't solve the issue (please see the attached picture).
Also, now I have another service wouldn't start "Ciscoworks Daemon Manager".
Hi ,
You are not running the commad from the right location ,it should be
Run the command again.. you should see the output of this comman:
        Process      = Apache
        Startup      = y
Afroz
Thank you very much for following up,
Hope there is a soluation for this issue.
Duong Nguyen
Level 3
Level 3
Give us a screen shot all of that Services that are running.
In windows --> start-->run-->services.msc
Regarding the srevices, now I have two services wouldn't start (labeled by red).
PIC1: services
PIC2: Error message
PIC3: Error message
PIC4: List of patches
Hope this will clarify the issue
shut down the daemon services, then bounce the apache services again
Your LMS server is it a stand alone server? or do you have another application installed on it as well?
Search for theses files and verify its located in CSCOpx\bin folder/directory and in windows\system32 folder
cwssleay32.dll
cwlibeay32.dll
If you have duplicates of these files, try renaming or removing them other than the cscopx folder.
I have checked, these files weren't in the "windows\system32" directory. I have copied them from "CSCOpx\bin" and pasted them in "windows\system32" directory, but it didn't solve the issue.
Also, please note that the daemon service is down and I couldn't run it !
Try this :
on the Cmd prompt :
NMSROOT/CSCOpx/setup/support>resetCasuser.exe
Reset the Casuser Password and then try to start the Daemon Manager
Afroz
Unfortunately it didn't solve the issue.
I gave up, I just restored an old backup for the server. It is better to have it working with old data than have it corrupted.
Anyway, thank you all for your help.
Have a great day
what version are you running?
The version is 3.2. The paln is to upgrade it to the latest version 4.x.
