05-07-2013 07:17 AM
Hi All,
My LMS version 3.2 with SP 1. ANIServer status is found to be failed to run and while executing "pdshow ANIServer", observed that " Info = Application failed or was registered incorrect".
Checked the ANIServer.properties, and the entry is like the below..
DEVICESROOT=E:\\progra~4\\campus\\lib\\classpath
Checked the ANIServer.properties.orig, and the entry is like the below..
DEVICESROOT=
which means no entry, might be it should not have such entry, i dont know..
Hence the possible work arounds in my mind are 1) ani.log log recovery 2) ani db reinitialization etc.. Is there any thing else i need to try ??
Can someone help plz..
regards
Rajesh
05-07-2013 08:33 AM
That can be very messy. I'd go straight to a TAC case if you have support.
If you need to reinitialize a db on your own, I'd refer to Joe Clarke's how-to document.
05-07-2013 09:11 AM
This seems perfectly allright : DEVICESROOT=E:\\progra~4\\campus\\lib\\classpath. If by pasting this in to run field, your exloprer opens NMSROOT\campus\lib\classpath folder, than this is not the cause of the issue.
You should share the output of pdshow and pdreg -l ANIServer.
-Thanks
05-20-2013 03:06 AM
