CiscoWorks device discovery with Multiple SNMP commu.
majid.zein
Our network is configured with multiple SNMP read community strings for security reasons, the problem is that CiscoWorks is not being able to discover all devices. It discovers only those with the same SNMP community to which it is attached? Does the fact that we're using L3 to the edges have anything to do with that?
I have enabled multiple community string in the SNMP settings and the "Jump router Boundaries" in the discovery settings.
Thank you for your help
David Stanford
Which version of CM are you running? What do you mean "discovers only those with the same SNMP community to which it is attached"?
Do you have multiple entries configured in your snmp settings with different wildcards? Have you enabled multiple comm string support?
