Ciscoworks: Device not appearing in Campus Manager
raza555
Level 3
Level 3
I have added 3 new devices in CS and then create a group in RME then add the 3 devices in this group. Then I have run the credential check added devices in inventory and backup the configuration successfully.
Problem:
These devices are not appearing in the CM, In can see a new group but when I generate a User Tracking Report in Campus Manager, I am getting a popup saying "no end host found"
Device type are one 3750g-24ts switch and two 2611 routers.
I have restarted the services twice via net stop crmdmgtd; net start crmdmgtd, but no gain.
Please guide me that how I can make the devices appear in CM, there are many other devices already exist in CM. Also we only add devices manually, bot via discovery.
I am using
LMS: 3.2
CM: 5.2.1
RME: 4.3.1
Svetlana Radzevich
Run a Data Collection in Campus Manager (Campus Manager -> Home -> Start data collection). Does it improve the situation?
I have run the Data Collection in Campus Manager 3 times but still unable to see the 3 devices in campus manager.
Also it seems that CM is talking with CS as for trial I have deleted 1 switch from CS and it also get deleted in CM & RME
Please advise any other solution.
