CiscoWorks - Discovery Metrics
1lumkk
Problem: Interfaces VLAN in a single unit of 6500 are discovered by Ciscoworks as a unknown device. Directly, the system is generating false topology mapping of the actual network infro.
Any one has any idea how to overcome this?
wong34539
Level 6
Level 6
check if CDP is running on that interface, if CDP is disabled on the interface, it will not be discovered.
