CiscoWorks error
andresfmg
"Message
Cannot find applicable device package for 192.168.3.252
This error could be due to one of the following:
- The device package for this device type is not installed.
- Device support for this device type is not available.
- You are trying to open a component inside a device.
To correct the problem, either install a device package for the device type, or open the
parent device to manage the component."
I applied updates in update device option.
THe following applies.
2960g version package 5.0
any idea?
Joe Clarke
What version of CiscoView? What is the sysObjectID of this 2960G switch?
