Ciscoworks issue_dfm
secureIT
Level 7
Level 7
Dear All,
I have configured LMS 4.2.3 to do snmptraps forwarding to the below linux servers and im not getting any traps in those servers..
I do see dfm traps generated under dfm\alerts and activities window...
These servers are located in different locations and not in the same where ciscoworks server is located.
Can you pls check the attached configuration., and suggest are the snmp trap forwarding ip addresses &&& snmp trap recipients the same ??
11.1.1.1
12.1.1.1
13.1.1.1
14.1.1.1
15.1.1.1
regards
Rajesh
ngoldwat
Level 9
Level 9
Have you verified the traps make it all the way to their destination?
All traps are forwarded in V1 (SNMP Version) format.
Here is a link to:
Monitoring and Troubleshooting with Cisco Prime LAN Managmement Solution 4.2
Hope this helps.
