CiscoWorks LMS 3.2 SMTP configuration giving error
Pravin Kondhare
HI Friends,
I have installed Ciscoworks 3.2 on Dell poweredge 2950 server, when i try to configure SMTP email notification settings, it's giving me error "Invalid IP address or server name please enter valid SMTP server name"
Request you to all please help me.
Svetlana Radzevich
Are you able to telnet from the CW server to your SMTP server on port 25? I.e.
telnet 25
Also check your regdaemon.xml file under $NMSRoot\MDC\etc - particular entry SMTPServerName. Is it correct configured there? Do you have only one entry with this name?
  We have edited the file but Common Services does not send e-mails still.  DFM works though for the same SMTP server.
how can we make the common services work properly?
share your solutions to us.
thanks.
I had the same situation on my LMS 3.2.
I had to change the SMTP server and got the message, that the IP-address or name of the server is invalid.
I changed the file, too. But it is not working.
For testing I created a new discovery job and the system sends a info mail to for such activity.
I got the following error message:
MailID is not given by user. Hence, No mail will be sent for this scheduling.
Maybe somebody can give more advice to this.
Sven
