Ciscoworks lms 4.1 - Problem Instance Polling
MaliqueVince
Hi everyone,
I created many poller to monitor templates on my dashboard.
When I created a poller to monitor CPU Utilization my poller is in "instance polling".
In the section Monitor > Performance Settings > Setup >
- Automonitor : instance polling
- Poller status : instance polling
I used MIB Variable for CPU :cpmCPUTotal5minRev
And I want to manage Cisco 2960.
How can i've got a polling status : OK ???
Thank's for your consideration and your help
MaliqueVince
I keep my poller in status "instance polling" and I create a new poller to monitor CPU utilization
When I do it, I've got this message :
Error :
No Instances are found in the devices. This could be because the device  is unreachable, or the device does not have the instances for the  selected templates, or the time out value is low.
This is the procedure that I follow when I add a poller : I select my devices Cisco 2960, I select my MIB template "cpmCPUTotal5minRev " that I created and I add this to "selected template" and I click on Next.
I already create many poller to monitor : Device Availability, Memory Utilization, Bandwidth interfaces and Interfaces Availability and I haven't problem.
Please, someone could help me to solve my problems ?
Thank's !
MaliqueVince
I found my error !
When I purge my syslog configuration (log rotation) all the services are stopped.
I start them and it's works !
