Ciscoworks LMS DCRServer is down.
I'm facing issues with LMS 3.2 Ciscoworks application.
We were getting alerts for Diskfull and hence we deleted some log files from /var directory.
But since then, DCRserver for the appliction is coming up. Due to this we have lost all the device data base.
I tried starting up the DCRserver from Common Services -> Admin -> process but the process keeps in 'Waiting to initialize'.
When I checked into the DCRServer process I got the following flagsas in attached picture.DCSServer.JPG
I have also checked the dependencies provided in the screenshot. All the process are running fine.
Kindly someone help to bring the DCRServer up.
5 Replies 5
Vinod Arya
Please run /opt/CSCOpx/bin/pdshow and share result. Also, shut down daemon manager > Clear logs from Deamons.log and restart daemon manager and share daemons.log as well.
It is very strange if clearing logs from  /var affected DCRServer. In /var /var/adm/CSCOpx/log is where all the logs for LMS are stored and under /var/CSCOpx/log syslog_info is located. Apart from this, LMS uses /var/adm/CSCOpx/files/rme/ directory for configuration files.
So removing any of the above even completely would never affect DCRServer. It seems issue should be something else.
Moreover, to keep the size of your logs under control, you should use the Logrot utility. For more details check Configuring Log Files Rotation section of user guide.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod,
Thanks for your response. The following are the results
Process= ANIDbEngine
State  = Program started - No mgt msgs received
Pid    = 18694
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:05
Stop   = Not applicable
Core   = Not applicable
Info   = Application started by administrator request.
Process= WlseUHIC
State  = Running normally
Pid    = 18704
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:09
Info   = Started.
Process= CmfDbEngine
Pid    = 18705
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:10
Process= CmfDbMonitor
Pid    = 18725
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:14
Info   = DbMonitor Running Normally.
Process= ESS
Pid    = 18726
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:15
Process= EssMonitor
Pid    = 18727
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:19
Info   = ESS is fully up now !
Process= EventFramework
Pid    = 18728
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:34
Process= SyslogCollector
Pid    = 18729
RC     = 0
Signo  = 0
Process= MACUHIC
Pid    = 18730
RC     = 0
Signo  = 0
Info   = Started.
Process= UTLITE
Pid    = 18731
RC     = 0
Signo  = 0
Info   = Started.
Process= VNMServer
Pid    = 18732
RC     = 0
Signo  = 0
Process= RMEDbEngine
Pid    = 18733
RC     = 0
Signo  = 0
Process= UPMDbEngine
Pid    = 18743
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:38
Process= UPMDbMonitor
Pid    = 18753
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:42
Process= IpmDbEngine
Pid    = 18754
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:43
Process= DFMLogServer
Pid    = 18764
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:47
Process= DFMCTMStartup
State  = Administrator has shut down this server
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:18:02
Stop   = 07/01/13 12:18:05
Process= FHPurgeTask
State  = Transient terminated
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/05/13 00:00:02
Stop   = 07/05/13 00:00:14
Info   = DPS Task FHPurgeTask completed at Fri Jul 05 00:00:13 EDT 2013. For status check Job Browser UI.
Process= DfmBroker
Pid    = 18766
RC     = 0
Signo  = 0
Process= DfmServer
Pid    = 18794
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:51
Info   = DfmServer initialized OK.
Process= DfmServer1
Pid    = 18795
RC     = 0
Signo  = 0
Info   = DfmServer1 initialized OK.
Process= FHDbEngine
Pid    = 18796
RC     = 0
Signo  = 0
Process= INVDbEngine
Pid    = 18873
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:55
Process= PMServer
Pid    = 18883
RC     = 0
Signo  = 0
Start  = 07/01/13 11:55:59
Info   = PMServer is up and running
Process= EPMDbEngine
Pid    = 18884
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:03
Process= EPMServer
Pid    = 18894
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:07
Info   = EPMServer is up and running
Process= AdapterServer
Pid    = 18895
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:11
Process= AdapterServer1
Pid    = 18896
RC     = 0
Signo  = 0
Process= FHServer
Pid    = 18897
RC     = 0
Signo  = 0
Info   = FHServer started.
Process= DFMMultiProcLogger
Pid    = 18898
RC     = 0
Signo  = 0
Process= ProcSysBus
Pid    = 18899
RC     = 0
Signo  = 0
Process= OpsxmlDbEngine
Pid    = 18900
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:15
Process= OpsXMLRuntime
Pid    = 18910
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:19
Process= CWAPublisher
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 07/01/13 12:22:07
Process= CSDiscovery
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:29
Stop   = 07/01/13 12:20:40
Process= DCRDevicePoll
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 07/01/13 12:20:50
Process= CSRegistryServer
Pid    = 18953
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:23
Info   = CSRegistryServer is running
Process= Tomcat
Pid    = 18955
RC     = 0
Signo  = 0
Process= TomcatMonitor
Pid    = 19009
RC     = 0
Signo  = 0
Start  = 07/01/13 11:56:27
Info   = Tomcat Server up
Process= Apache
Pid    = 19141
RC     = 0
Signo  = 0
Start  = 07/01/13 12:01:55
Info   = Web Server initialized ok.
Process= DCRServer
State  = Waiting to initialize.
Pid    = 1015
RC     = 0
Signo  = 0
Start  = 07/03/13 06:22:40
Process= CMFOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:06
Stop   = 07/03/13 05:50:28
Info   = Application dependency stop: depends on stopped application(s).
Process= CampusOGSServer
State  = Never started
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Info   = Not applicable,
Process= EssentialsDM
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:10
Stop   = 07/03/13 05:50:26
Process= RMEOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:49
Stop   = 07/03/13 05:50:24
Process= PMCOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ICServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ConfigMgmtServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= UTManager
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= TISServer
Pid    = 0
RC     = -113
Signo  = 0
Stop   = 07/03/13 05:50:22
Process= DFMOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:33
Stop   = 07/03/13 05:50:18
Process= NOSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= PTMServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= InventoryCollector
Pid    = 0
RC     = -113
Signo  = 0
Start  = 07/01/13 12:20:37
Stop   = 07/03/13 05:50:16
Process= Interactor
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= InventoryCollector1
Pid    = 0
RC     = -113
Signo  = 0
Start  = 07/01/13 12:20:41
Stop   = 07/03/13 05:50:12
Process= Interactor1
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= UPMProcess
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= LicenseServer
Pid    = 19293
RC     = 0
Signo  = 0
Start  = 07/01/13 12:06:55
Process= FDRewinder
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 07/01/13 12:20:33
Process= NameServer
Pid    = 19294
RC     = 0
Signo  = 0
Process= NameServiceMonitor
Pid    = 19297
RC     = 0
Signo  = 0
Start  = 07/01/13 12:06:59
Info   = NameServer is fully up now !
Process= EDS
Pid    = 19298
RC     = 0
Signo  = 0
Start  = 07/01/13 12:07:03
Info   = Initialization complete
Process= ANIServer
State  = Running with busy flag set
Pid    = 19299
RC     = 0
Signo  = 0
Start  = 07/01/13 12:07:34
Info   = ANIServer started.
Process= UTMajorAcquisition
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:20:54
Stop   = 07/01/13 12:21:05
Process= EDS-GCF
Pid    = 19300
RC     = 0
Signo  = 0
Start  = 07/01/13 12:07:38
Info   = GCF Initialization complete at Mon Jul 01 12:08:08 EDT 2013
Process= jrm
Pid    = 19301
RC     = 0
Signo  = 0
Process= CTMJrmServer
Pid    = 0
RC     = -113
Signo  = 0
Start  = 07/01/13 12:20:21
Stop   = 07/03/13 05:50:10
Process= ChangeAudit
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= SyslogAnalyzer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= DataPurge
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:18:01
Stop   = 07/01/13 12:18:44
Info   = DataPurge initialization completed at Mon Jul 01 12:18:44 EDT 2013.
Process= IPMProcess
Pid    = 0
RC     = -113
Signo  = 0
Start  = 07/01/13 12:20:45
Stop   = 07/03/13 05:50:06
Process= IPMOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 5574
Pid    = 0
RC     = 1
Signo  = 0
Start  = 07/01/13 12:20:04
Stop   = 07/01/13 12:20:41
Process= 1194
Pid    = 0
RC     = 0
Signo  = 0
Start  = 07/01/13 12:19:58
Stop   = 07/01/13 12:20:30
Process= 1444
Pid    = 0
RC     = 1
Signo  = 0
Start  = 07/01/13 12:19:59
Stop   = 07/01/13 12:20:47
Process= 5060
Pid    = 0
RC     = 1
Signo  = 0
Start  = 07/01/13 12:20:03
Process= 2231
Pid    = 0
RC     = 1
Signo  = 0
Process= 3573
Pid    = 0
RC     = 1
Signo  = 0
Start  = 07/01/13 12:20:00
Stop   = 07/01/13 12:20:45
Process= 4426
Pid    = 0
RC     = 1
Signo  = 0
Start  = 07/01/13 12:20:02
Process= 1202
Pid    = 0
RC     = 1
Signo  = 0
Process= 3074
Pid    = 0
RC     = 1
Signo  = 0
Stop   = 07/01/13 12:20:48
Process= 2232
Pid    = 0
RC     = 1
Signo  = 0
Process= diskWatcher
Pid    = 19308
RC     = 0
Signo  = 0
Start  = 07/01/13 12:08:01
Info   = diskWatcher initialized OK.
Also the information from
/var/adm/CSCOpx/log/daemons.log
ERROR: open file dmgtd failedSQL Anywhere Network Server Version 10.0.1.3830
Copyright (c) 2001-2007, iAnywhere Solutions, Inc.
Portions copyright (c) 1988-2007, Sybase, Inc.
All rights reserved. All unpublished rights reserved.
This software contains confidential and trade secret information of
Use, duplication or disclosure of the software and documentation
by the U.S. Government is subject to restrictions set forth in a license
agreement between the Government and iAnywhere Solutions, Inc. or
other written agreement specifying the Government's rights to use the
software and any applicable FAR provisions, for example, FAR 52.227-19.
iAnywhere Solutions, Inc., One Sybase Drive, Dublin, CA 94568, USA
16 physical processor(s) detected.
Networked Seat (per-seat) model. Access to the server is limited to 10 seat(s).
This server is licensed to:
    cisco
    cisco
Running SunOS 5.10 Generic_142900-12 on SPARC
Server built for SPARC processor architecture
8192K of memory used for caching
Minimum cache size: 8192K, maximum cache size: 7538688K
Using a maximum page size of 4096 bytes
Starting database "aniDb" (/opt/CSCOpx/databases/ani/ani.db) at Fri Jul 05 2013 15:10
Transaction log: ani.log
Starting checkpoint of "aniDb" (ani.db) at Fri Jul 05 2013 15:10
Finished checkpoint of "aniDb" (ani.db) at Fri Jul 05 2013 15:10
Database "aniDb" (ani.db) started at Fri Jul 05 2013 15:10
Database server started at Fri Jul 05 2013 15:10
Trying to start SharedMemory link ...
    SharedMemory link started successfully
Trying to start TCPIP link ...
    TCPIP link started successfully
Now accepting requests
    cisco
    cisco
Starting database "cmfDb" (/opt/CSCOpx/databases/cmf/cmf.db) at Fri Jul 05 2013 15:10
Transaction log: cmf.log
Starting checkpoint of "cmfDb" (cmf.db) at Fri Jul 05 2013 15:10
Finished checkpoint of "cmfDb" (cmf.db) at Fri Jul 05 2013 15:10
Database "cmfDb" (cmf.db) started at Fri Jul 05 2013 15:10
MESSAGE WlseMain: Properties will be read from /opt/CSCOpx/campus/etc/cwsi/WlseUhic.properties
Informational: Starting Cisco Process Manager communication thread
messages will be logged to file: /var/adm/CSCOpx/log/wlseuhic.log
ACTIVEMQ_HOME: objects/ess
ACTIVEMQ_BASE: objects/ess
Loading message broker from: xbean:activemq.xml
[ Fri Jul 05 15:10:48 EDT 2013 ]EssMonitor: theMgr constructor successful.
INFO  BrokerService                  - ActiveMQ 4.1.1 JMS Message Broker (localhost) is starting
INFO  BrokerService                  - For help or more information please see: http://incubator.apache.org/activemq/
INFO  ManagementContext              - JMX consoles can connect to service:jmx:rmi:///jndi/rmi://localhost:1099/jmxrmi
INFO  JDBCPersistenceAdapter         - Database driver recognized: [apache_derby_embedded_jdbc_driver]
INFO  DefaultDatabaseLocker          - Attempting to acquire the exclusive lock to become the Master broker
INFO  DefaultDatabaseLocker          - Becoming the master on dataSource: org.apache.derby.jdbc.EmbeddedDataSource@1bfa3d3
INFO  JournalPersistenceAdapter      - Journal Recovery Started from: Active Journal: using 5 x 20.0 Megs at: /opt/CSCOpx/objects/ess/activemq-data/journal
INFO  JournalPersistenceAdapter      - Journal Recovered: 0 message(s) in transactions recovered.
INFO  TransportServerThreadSupport   - Listening for connections at: tcp://uapit011.global.sabic-ip.com:42351
INFO  TransportConnector             - Connector openwire Started
INFO  NetworkConnector               - Network Connector default-nc Started
INFO  BrokerService                  - ActiveMQ JMS Message Broker (localhost, ID:uapit011.global.sabic-ip.com-60007-1373051449476-1:0) started
[ Fri Jul 05 15:11:02 EDT 2013 ]ESS Published successfully
[ Fri Jul 05 15:11:02 EDT 2013 ]EssMonitor: CreateReadyFile success.
[ Fri Jul 05 15:11:02 EDT 2013 ]EssMonitor: SendOkMsg success.
    cisco
    cisco
16384K of memory used for caching
Minimum cache size: 16384K, maximum cache size: 2097152K
Starting database "rmengdb" (/opt/CSCOpx/databases/rmeng/rmeng.db) at Fri Jul 05 2013 15:11
perf end to end false
perf stage wise false
perf end to end falseInit Controlers
Init Controlers
Properties Loaded from /opt/CSCOpx/campus/lib/classpath/com/cisco/nm/cm/ut/uhic/mac/properties/macuhic.properties
Properties Loaded from /opt/CSCOpx/campus/lib/classpath/com/cisco/nm/cm/ut/uhic/utlite/properties/utliteuhic.properties
NMSROOT is /opt/CSCOpx
propFile/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes//opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties
Unable to find the file /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes//opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties
propFile/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties
messages will be logged to file: utlite.logmessages will be logged to file: macuhic.log
Opening dbspace 'SYSLOGFIRST' in file 'SyslogFirst.db' for database 'rmengdb'
Opening dbspace 'SYSLOGSECOND' in file 'SyslogSecond.db' for database 'rmengdb'
Opening dbspace 'SYSLOGTHIRD' in file 'SyslogThird.db' for database 'rmengdb'
Transaction log: rmeng.log
Starting checkpoint of "rmengdb" (rmeng.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "rmengdb" (rmeng.db) at Fri Jul 05 2013 15:11
Database "rmengdb" (rmeng.db) started at Fri Jul 05 2013 15:11
Database server started at Fri Jul 05 2013 15:11
    cisco
    cisco
262144K of memory used for caching
Minimum cache size: 262144K, maximum cache size: 7538688K
Starting database "upm" (/opt/CSCOpx/databases/upm/upm.db) at Fri Jul 05 2013 15:11
Transaction log: upm.log
Starting checkpoint of "upm" (upm.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "upm" (upm.db) at Fri Jul 05 2013 15:11
Database "upm" (upm.db) started at Fri Jul 05 2013 15:11
    cisco
    cisco
Minimum cache size: 16384K, maximum cache size: 4190208K
Starting database "ipm" (/opt/CSCOpx/databases/ipm/ipm.db) at Fri Jul 05 2013 15:11
Transaction log: ipm.log
Starting checkpoint of "ipm" (ipm.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "ipm" (ipm.db) at Fri Jul 05 2013 15:11
Database "ipm" (ipm.db) started at Fri Jul 05 2013 15:11
log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again later.
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:520)
at java.net.Socket.connect(Socket.java:470)
at java.net.Socket.(Socket.java:367)
at java.net.Socket.(Socket.java:209)
at org.apache.log4j.net.SocketAppender.connect(SocketAppender.java:301)
at org.apache.log4j.net.SocketAppender.activateOptions(SocketAppender.java:255)
at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:247)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:123)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)
at org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:637)
at org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:595)
at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:522)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:412)
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:436)
at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:455)
at org.apache.log4j.Category.(Category.java:146)
at com.cisco.nm.xms.ctm.registry.CTMRegistryStarter.(CTMRegistryStarter.java:15)
MAIN-N-Closing this log file at 05-Jul-2013 15:11:18; continuing in
    /opt/CSCOpx/objects/smarts/local/logs/brstart.log
    cisco
    cisco
32760K of memory used for caching
Minimum cache size: 32760K, maximum cache size: 32760K
Starting database "dfmFhDb" (/opt/CSCOpx/databases/dfmFh/dfmFh.db) at Fri Jul 05 2013 15:11
Transaction log: dfmFh.log
Starting checkpoint of "dfmFhDb" (dfmFh.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "dfmFhDb" (dfmFh.db) at Fri Jul 05 2013 15:11
Database "dfmFhDb" (dfmFh.db) started at Fri Jul 05 2013 15:11
    cisco
    cisco
Minimum cache size: 32760K, maximum cache size: 7538688K
Starting database "dfmInvDb" (/opt/CSCOpx/databases/dfmInv/dfmInv.db) at Fri Jul 05 2013 15:11
Transaction log: dfmInv.log
Starting checkpoint of "dfmInvDb" (dfmInv.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "dfmInvDb" (dfmInv.db) at Fri Jul 05 2013 15:11
Database "dfmInvDb" (dfmInv.db) started at Fri Jul 05 2013 15:11
at org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:309)
at org.apache.log4j.PropertyWatchdog.doOnChange(PropertyConfigurator.java:665)
at org.apache.log4j.helpers.FileWatchdog.checkAndConfigure(FileWatchdog.java:80)
at org.apache.log4j.helpers.FileWatchdog.(FileWatchdog.java:49)
at org.apache.log4j.PropertyWatchdog.(PropertyConfigurator.java:657)
at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:373)
at org.apache.log4j.PropertyConfigurator.configureAndWatch(PropertyConfigurator.java:355)
at com.cisco.nm.trx.LogService.ItemLog.loadMyLogConf(ItemLog.java:142)
at com.cisco.nm.trx.LogService.ItemLog.(ItemLog.java:86)
at com.cisco.nm.trx.LogService.ItemLog.getInstance(ItemLog.java:202)
at com.cisco.nm.trx.pm.server.PMServer.(PMServer.java:58)
05/Jul/2013 15:11:32:836 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
05/Jul/2013 15:11:32:854 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
    cisco
    cisco
Minimum cache size: 32760K, maximum cache size: 131072K
Starting database "dfmEpmDb" (/opt/CSCOpx/databases/dfmEpm/dfmEpm.db) at Fri Jul 05 2013 15:11
Transaction log: dfmEpm.log
Starting checkpoint of "dfmEpmDb" (dfmEpm.db) at Fri Jul 05 2013 15:11
Finished checkpoint of "dfmEpmDb" (dfmEpm.db) at Fri Jul 05 2013 15:11
Database "dfmEpmDb" (dfmEpm.db) started at Fri Jul 05 2013 15:11
05/Jul/2013 15:11:36:595 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/Jul/2013 15:11:36:596 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
05/Jul/2013 15:11:36:597 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
at com.cisco.nm.trx.epm.providers.IptmLoggerImpl.(Unknown Source)
at com.cisco.nm.trx.epm.Epm.logger(Unknown Source)
at com.cisco.nm.trx.epm.Epm.log(Unknown Source)
at com.cisco.nm.trx.epm.process.EpmMain.main(Unknown Source)
at com.cisco.nm.trx.LogService.ItemLog.(ItemLog.java:121)
couldn't read from configuration file
Server Started....
Version = 2.0.0.25
Listening on 10002=>Local
at com.cisco.nm.trx.iptfh.collector.FHDataCollectorMain.main(FHDataCollectorMain.java:40)
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)log4j:ERROR Could not connect to remote log4j server at [localhost]. We will try again later.
at org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:87)          at org.apache.log4j.PropertyConfigurator.parseCatsAndRenderers(PropertyConfigurator.java:522)
at com.cisco.nm.trx.adapters.admin.Adapters.initilizeLogging(Adapters.java:201)
at com.cisco.nm.trx.adapters.admin.Adapters.(Adapters.java:35)
at com.cisco.nm.trx.adapters.admin.Adapters.main(Adapters.java:224)
at com.cisco.nm.trx.adapters.admin.Adapters.initilizeLogging(Adapters.java:208)
Looking forward for your inputs !!!
There are many processes which are down if you check many essential services are down and error such as URN_NOT_FOUND etc can be seen. Ideally such messages appear when ports required LMS are already acquired by some other processes.
In case your server has installed any other software, please uninstall or disable it and following this procedure once :
a.Stop Daemons
/etc/init.d/dmgt stop
b. Remove server.* under CSCOpx\MDC\Apache\conf\ssl   ( kindly take backup of these somewhere else before deleting from here)
c. Run the following commands:
CSCOpx\MDC\Apache\perl ConfigSSL.pl -disable
CSCOpxMDC\Apache\perl ConfigSSL.pl -enable (fill up  the certificate info)
d. Please delete ctmregistry and ctmregistry.backup from CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/. (take backup of these files to some another directory.)
d.Restart Daemons
/etc/init.d/dmgt start
-Thanks
Hi Vinod,
Went through the following steps. But still issue remains.
1) Remove server.* under /opt/CSCOpx/MDC/Apache/conf/ssl   ( kindly take backup of these somewhere else before deleting from here)
2) Run the following commands:
/opt/CSCOpx/MDC/Apache/bin/ConfigSSL.pl -disable
/opt/CSCOpx/MDC/Apache/bin/ ConfigSSL.pl -enable (fill up  the certificate info)
3) Please delete ctmregistry and ctmregistry.backup from /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib (take backup of these files to some another directory.)
4)Restart Daemons
sudo /etc/init.d/dmgtd start
Can you plesae suggest an alternate method to try out
Even after this is the issue persist I request you to share the same details as before. Daemons.log and output of pdshow to see if the other processes are down as well.
-Thanks
