CiscoWorks Process Management
Twofold question:
1. Which processes start automatically when CW starts or after 'net start crmdmgtd' and which must be started manually?
2. What is CMLogger and where/how is it loaded? In Process Status, there are several processes dependent on it, but it is not listed, and does not show under the drop down list in Start Process.
amritpatek
Level 6
Level 6
1) Mostly all Ciscoworks processes are started after 'net start crmdmgtd'.
2) Some processes are transient and only started when nedded.
3) Other than processes, there is also Ciscoworks services, which will listed under Windows's Services. They will automatically started when Windows come up.
