Bookmark
Subscribe
1033
Ciscoworks product specs
adam0zimek
Hello all,
Wondering if there's anyone out there that can point me in a good direction for ciscoworks resources. I am interested in the product, know the general idea of the application, but need some good specifics on the product line and features.
Any advice would be great, Thanks,
-Adam
Joe Clarke
This might be a good place to start for LAN Management Solution: http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html .
If you want to see LMS at work - there is also the possibility to get the evaluation CDs of LMS. You can test the sw for 90 days and if you decide to buy it you just need to license the eval installation and you will get a full licensed one without reinstalling.
You should get the eval version from the partner where you buy your cisco equipment.
